Dive Setup
You can customize the dive settings based on your needs. Not all settings are applicable for all dive modes. You can also edit the settings before you start a dive.
Hold MENU, and select Dive Setup.
- Gases
Sets the gas blends used in the gas dive modes (Setting Up Your Breathing Gases). You can have up to twelve gases for each gas dive mode.
- Conservatism
Sets the level of conservatism for decompression calculations. Higher conservatism provides a shorter bottom time and a longer ascent time. The Custom option allows you to set a custom gradient factor.
NOTE: Make sure you understand gradient factors before entering a custom level of conservatism. - Water Type
Allows you to select the water type.
- PO2
Sets the partial pressure of oxygen (PO2) thresholds, in bar, for the maximum operating depth (MOD), decompression, warnings, and critical alerts (Setting PO2 Thresholds).
- Scuba Alerts
Allows you to set custom alerts for gas dives (Custom Dive Alerts).
- Apnea Alerts
Allows you to set custom alerts for apnea dives (Custom Dive Alerts).
- Safety Stop
Allows you to change the safety stop duration.
- Last Deco Stop
Allows you to set the depth of the final decompression stop.
- End Dive Delay
Allows you to set the length of time before the device ends and saves a dive after surfacing.
- CCR Setpoints
Allows you to set high and low PO2 setpoints for closed-circuit rebreather (CCR) dives (Setting CCR Setpoints).
- Backlight
Allows you to adjust the backlight settings for dive activities. You can enable the backlight throughout the dive or only when you are at depth.
- Heart Rate
Allows you to enable or disable a heart rate monitor for dives. The Stored Strap Data option allows you to enable a chest heart rate monitor, such as the HRM-Swim™ or HRM-Tri™ device, that stores heart rate data with the dive. You can view chest heart rate monitor data in the Garmin Dive™ app after you complete the dive.
- Double Tap to Scroll
Allows you to double tap the device to scroll through the dive data screens. If you notice accidental scrolling, you can use the Sensitivity option to adjust the responsiveness.
- UP Key
Allows you to enable or disable the UP button during dive activities to prevent inadvertent button presses.
- Silent Diving
Allows you to disable all tones and vibrations for alerts during dive activities.
- No-Fly Time
Allows you to set the no-fly countdown timer mode (No-Fly Time).
- Deco Lockout
Allows you to disable the decompression lockout feature. This feature prevents single-gas, multi-gas, and CCR dives for 24 hours if you violate a decompression ceiling for more than three minutes.
NOTE: You can still disable the decompression lockout feature after violating a decompression ceiling.
- Setting Up Your Breathing Gases
- Custom Dive Alerts
- Setting PO2 Thresholds
- Setting CCR Setpoints
- No-Fly Time
