You can enter up to twelve gases for each gas dive mode. Decompression calculations include your decompression gases, but do not include your backup gases.
Hold
MENU.
Select
Select a dive mode.
Select the first gas in the list.
For single-gas or multi-gas dive modes, this is the bottom gas. For the closed-circuit rebreather (CCR) dive mode, this is the diluent gas.
Select
Oxygen, and enter the oxygen percentage of the gas blend.
Select
Helium, and enter the helium percentage of the gas blend.
The device calculates the remaining percentage as the nitrogen content.
Press
BACK.
Select an option:
NOTE:
Not all options are available for all dive modes.
Select
Add Backup, and enter the oxygen and helium percentage for your backup gas.
Select
Add New, enter the oxygen and helium percentage, and select
Mode to set the intended use for the gas, such as decompression or backup.
NOTE:
For the multi-gas dive mode, you can select
Set as Travel Gas to set a decompression gas as your intended gas for descending.
