User Waypoint, Create and Edit
User Waypoints can be created and used for flight planning and for identifying a specific location on the map. User Waypoints can be created as Route or Airport waypoints using the Type Button. Once a waypoint has been created, it can be modified, deleted, or moved. Saved user waypoints are stored for future use. A user waypoint cannot be modified or deleted if it is part of the Active Flight Plan.
Any one of the following parameters may be used for defining the location of a user waypoint: Radial/ Distance, Radial/Radial, LAT/LON Coordinates, or Present Position.
170: Creating User Waypoints using the Radial Menu
171: Initiating the 'Create User Waypoint' Function on the MFW
172: 'Create User Waypoint' Mode Options
173: 'Create User Waypoint' Type Options
190-03123-21 Rev B
October 2026
