Data Bar
The Data Bar is the strip of data that is displayed across the top of the AXIS™ flight display. It is able to display many pertinent fields of data for the pilot to have quick reference to. Up to eight fields of data from the following list can be displayed across the top of the screen. The amount of data fields displayed depend upon the amount of space available on the CNS bar. If, for example, only one communication radio and one navigation radio are displayed, the amount of available space in the upper portion of the screen is enough to display eight fields of data. If the Emergency Button (EMER) is then enabled to be displayed, the space at the top of the screen is prioritized to fit the most pertinent information, consequently removing the last data field from the data bar.
25: (Configurable) Data Bar
Table 2: Optional Data Bar Fields
  • Bearing to Next Waypoint
  • Distance/Bearing to Destination
  • Desired Track to Next Waypoint
  • Estimated Time of Arrival at Destination
  • Estimated Time Enroute to Next Waypoint
  • Glide Ratio
  • Landing Field Elevation
  • Mach Number
  • Radar Altitude
  • True Airspeed
  • Time Over Target (Next)
  • VOR/LOC Info
  • Ceiling and Visibility at Destination
  • Current Cabin Altitude
  • Destination
  • Enroute Safe Altitude to Destination
  • Estimated Time of Arrival at Next Waypoint
  • G Meter
  • Ground Speed
  • Local 12H Time
  • Minimum Safe Altitude
  • Ram Air Temperature
  • Track Angle Error
  • Current Track
  • Vertical Speed Requirement
  • Cross-Track error
  • Current Climb Gradient
  • Density Altitude
  • Enroute Safe Altitude to Next Waypoint
  • Estimated Time Enroute to Destination
  • GPS AGL Altitude
  • Difference from STD TEMP
  • Local 24H Time
  • Present Position Lat/Lon
  • Current Time at Destination
  • Time to Top of Descent
  • UTC Time
  • Winds at Destination
  • OFF
190-03123-21 Rev B
October 2026
