Radial Menu
The Radial Menu is displayed by touching anywhere on the 'Map' Application Page of the MFW. The Radial Menu displays context-sensitive buttons for information found within the inner radius of the menu. The context sensitive buttons provide details for airports, navigation aids, airspace, airways, obstacles, traffic, logbook tracks, elevation, estimated time enroute, and weather products. No matter where the Radial Menu appears, it will always provide the option to navigate direct to the location, create a user waypoint or graphically create/edit a flight plan. To reposition the Radial Menu, simply tap-drag it to a new location. Tap outside of the Radial Menu to close. Navigation data must be downloaded in order to make use of the Radial Menu. For more information refer to the Radial Menu section in the Flight Management chapter.
Table 3: Radial Menu Symbols
Radial Menu Symbol
Description
Radial Menu Symbol
Description
Airport
Hot Spot
Airspace
NOTAM
Airway
Obstacles
Create Waypoint
Menu
Direct-To
METAR
Datalink Radar
User Waypoint
Intersection
Insert in Flight Plan
More
Reroute
NDB
Insert Flight Plan
VORTAC
User Airspace
Visual Reporting Point (VRP)
Information displayed in the Radial Menu is determined by what is set in the Map/ Chart Settings. For example if airspace is turned off in the Map Settings, airspace information will not be presented in Radial Menu searches.
190-03123-21 Rev B
October 2026
