My sonar does not work Push the transducer cable all the way into the back of the device. Even if the cable seems to be connected, you should push firmly so that it is fully seated. Press , and ensure sonar is enabled. Select the correct transducer type (Selecting the Transducer Type). Parent Topic: TroubleshootingHomeAppendixTroubleshootingMy sonar does not work
