Changing Between 2D and 3D Views
By default, the OneVü™ sonar view shows a top-down 360-degree 2D view centered on your vessel. You can change this view to a 3D angle, which allows you to also overlay a LiveScope™ view on the OneVü sonar view if you have both types of transducers connected to a Spy™ pole.
  • Select Diagonal view symbol to change from the 2D view to the 3D view.
  • Select Vertical view symbol to change from the 3D view to the 2D view.
June 2026
