Customizing the Data Screens
You can show, hide, and change the layout and content of data screens for each dive mode.
  1. Select Dive Setup > Display Settings.
  2. Select a dive mode to customize.
  3. Select Data Screens.
  4. Select a data screen to customize.
  5. Select Menu.
  6. Select an option:
    • Select Layout to adjust the number of data fields on the data screen.
    • Select Data Fields, and select a field to change the data that appears in the field.
      TIP: For a list of all the available data fields, go to Data Fields.
    • Select Reorder to change the location of the data screen in the loop.
    • Select Remove to remove the data screen from the loop.
    NOTE: Not all options are available for each data screen.
  7. If necessary, select Add New to add a data screen to the loop.
    You can add a custom data screen, or select one of the predefined data screens.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
September 2026
