Data Fields
NOTE: Not all data fields are available for all activity types. Some data fields appear in more than one category on the dive computer.
Name
Description
Ascent Rate
The current rate of ascent toward the surface.
Average Depth
The average depth descended during a dive.
Avg Temperature
The average temperature during the dive.
Battery Percentage
The percentage of the battery power remaining.
Battery, Time, & Temp.
The percentage of the battery power remaining, the time of day based on your current location and time settings (format, time zone, daylight saving time), and the temperature of the air.
Compass
A visual representation of the direction in which the device is pointing.
Compass Heading
The direction you are moving based on the compass.
Conservatism
The level of conservatism for decompression calculations.
CNS
Your current central nervous system (CNS) oxygen toxicity percentage.
Current Gas PO2
The partial pressure of oxygen (PO2) of the current gas.
GF99
The current gradient factor. If you follow the dive computer's guidance, the selected low gradient factor should display when you approach your first decompression stop, and the selected high gradient factor value should display when you approach the surface. On-Gassing displays when you take on additional tissue load.
Maximum Depth
The maximum depth descended during a dive.
Max Temperature
The maximum temperature during the activity.
Min Temperature
The minimum temperature during the activity.
N2/He%
The nitrogen/helium tissue loading percentage.
NDL ↑3M / NDL ↑10FT
Your No Decompression Limit (NDL) time if you ascend 3 m (10 ft.) from your current depth.
NDL ↓3M / NDL ↓10FT
Your NDL time if you descend 3 m (10 ft.) from your current depth.
NDL Δ 3M / NDL Δ 10FT
Your NDL time if you ascend or descend 3 m (10 ft.) from your current depth.
None
This is a blank data field.
OTU
Your current oxygen toxicity units (OTU).
Raw Ceiling
The unrounded depth the diver should not ascend past.
Redundant Air Time Remaining
In a sidemount tank configuration, the air time remaining (ATR) for the tank with lower pressure.
Stopwatch
The stopwatch time for the current dive.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Surface Gradient Factor
The expected gradient factor if the diver were to instantaneously surface.
Temperature
The temperature of the water. Your body temperature affects the temperature sensor.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Time of Day (Seconds)
The time of day including seconds.
Time to Surface
The amount of time required to safely ascend to the surface, including decompression stops.
Tissue Graph (GF)
A bar chart displaying simulated values for nitrogen and helium in the body, with the y-axis of the field adjusted to your conservatism.
Tissue Graph (Raw)
A bar chart displaying simulated values for nitrogen and helium in the body.
TTS @ +5 min.
The amount of time required to safely ascend to the surface if you remain at your current depth for five minutes.
TTS Δ +5 min.
The difference between the amount of time required to safely ascend to the surface, and the amount of time required to safely ascend to the surface if you remain at your current depth for five minutes.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
September 2026
