Downloading Outdoor Maps+ Content
Before you can download Outdoor Maps+ content, you must purchase an Outdoor Maps+ subscription. Go to garmin.com/outdoormaps for more information.
You must connect your device to Wi‑Fi® before you can download Outdoor Maps+ content (Connecting to a Wi‑Fi Network).
To see Outdoor Maps+ content on the map, you must download the content for a specific area.
NOTE: Some Outdoor Maps+ layers are available only in certain areas.
  1. Select Settings > Map > Map Manager > Outdoor Maps+ > Download Maps.
  2. Select Layers with plus sign.
  3. Select each map layer you want to download.
    TIP: You can touch Context menu to see information about each map layer.
    The selected map layers are marked with a checkmark.
  4. Select Back to previous page.
  5. Drag the map and pinch to zoom in and out on the map until the highlighted rectangle covers the area for which you want to download map data.
    TIP: As you change the size of the area, the total download size and your current disk usage appear at the top of the screen.
  6. Select Arrow Down to start downloading.
    You can continue using your device while it downloads Outdoor Maps+ content.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
