Using the Map
You can use the map to navigate a route (Your Route on the Map) or to view a map of your surroundings when no route is active.
  1. Select View Map.
  2. Touch anywhere on the map.
  3. Select an option:
    • Drag the map to pan left, right, up, or down.
    • To zoom in or out, select Zoom in or Zoom out.
    • To switch between North Up, 2D, and 3D views, select Change map view.
    • To plan a route, drag the map to reveal the Route planner icon, and select Route planner (Planning a Route).
    • To start a route, select a location on the map, and select Go! (Starting a Route to a Point on the Map).
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
