Customizing the Map Layers
  1. From the map, select Map layers > Layers.
  2. Under Map Type, select a map type.
    With some map types, you can select Context menu > Hybrid Map to combine two map types.
    NOTE: The Satellite Imagery map shows satellite images only for areas where you have downloaded satellite imagery (Downloading Outdoor Maps+ Content).
  3. Under Map Details, select the types of information to display over the map.
    NOTE: Some layers are incompatible with each other and cannot be enabled at the same time. Enabling a layer automatically disables any incompatible layers.
    NOTE: Some map layers require an Outdoor Maps+ subscription.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
