Methods to Add a Contact to the Navigator
Entering the device ID
Allows you to add a contact that is not in the area. This method requires the contact to find and communicate their device ID to the person adding the device contact.
This method is helpful when you would like to add a contact during a hunt, but you are not near the device. For example, if you are adding another member of your hunting party to your navigator, but you do not own the device (Adding a Contact Using a Contact ID).
Receiving wirelessly
Allows you to add a navigator that you do not own as a contact. This method does requires the contact to share their device wirelessly. The two navigators must be within a range of 3 m (10 ft.) to share data wirelessly.
This method is helpful when you want to add a navigator during a hunt without entering the device ID (Adding a Contact Wirelessly From Another Navigator).
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
