Changing Your Contact ID
If you are experiencing interference from other collars or handheld devices in the area, you might need to change the contact ID for your navigator.
- From the main menu, select .
- Select a contact ID.
Each time a contact changes their contact ID, you must update the contact ID in your navigator (Updating a Contact ID).
Parent Topic: Methods to Add a Contact to the Navigator
