Adding a Contact Using a Contact ID
Before you can add a hunter using a contact ID, the hunter must find the contact ID (Finding Your Contact ID) and send it to you.
If you are not near the hunter you want to add, you can add the hunter using a contact ID.
  1. From the main menu, select Contacts icon > Add > Enter ID.
  2. Select a contact ID.
  3. Enter the name of the contact, and select Done.
The contact is added to your navigator
You can repeat this procedure using another hunter's navigator to add your contact ID to that device.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
