Pairing with a Watch or Cycling Computer
Before you can pair the Rally™ 110/210 pedals with a compatible watch or bike computer, you must pair the pedals with the Garmin Connect™ app (Pairing with the Garmin Connect App).
You can follow the steps to pair your Rally 110/210 pedals with a device that supports secure connections (Secure Connections).
To pair with a device that does not support secure pairing, you must set your pedals to allow open connections (Allowing Open Connections).
After you have paired the pedals with a compatible watch or cycling computer, you should set the correct crank length, to ensure accurate power measurements (Entering the Crank Length).
Parent Topic: Secure Connections
