Allowing Open Connections
The Rally™ 110/210 pedals support secure Bluetooth® connections with compatible devices. To pair the Rally 110/210 pedals with older devices that do not support secure pairing, you must configure the pedals to allow open connections.
The status LED on the Rally 110/210 pedal flashes three times when it is idle and allowing open connections.
You can pair your device by adding the Rally 110/210 pedals as a new sensor.
NOTE:
While allowing open connections, you can still turn on secure pairing mode and pair securely
with supported devices.
Parent Topic: Pairing with a Watch or Cycling Computer
