Pairing with the Garmin Connect App
  1. Rotate the cranks to wake up the pedals.
    NOTE: If the pedal status LED does not start flashing, the pedals may be in travel mode (Turning Off Travel Mode).
  2. Select an option:
    • If the left pedal status LED flashes Magenta (magenta), the pedals are in secure pairing mode. Go to step 3.
    • If the left pedal status LED flashes Green (green) or Blue (blue), enable secure pairing mode (Resetting the Pedals).
  3. Select an option to start pairing the Rally™ 110/210 pedals with the Garmin Connect™ app:
    • Scan the QR code with your phone.
      Rally pairing QR code
    • In the Garmin Connect app, select Menu symbol > Garmin Devices > Add Device.
  4. Select Connect It.
  5. Follow the on-screen instructions.
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
