Installing the Pedals
These instructions show the Rally™ RK pedal body. The steps are the same for any Rally 110/210 pedal body type.
NOTICE
Do not install the Rally 110/210 pedals with pedal boots or extenders. Pedal boots or extenders may damage the electronics in the spindles, leading to product malfunction.
NOTE: You should install the right pedal first.
  1. Apply a thin layer of grease to the pedal spindle threads.
    Tube of bike grease and the device
    NOTICE
    You must apply grease to the threads on the pedal before installing them. Installing the pedals without grease may lead to product damage.
  2. Insert the spindle into the crank arm.
  3. Hand tighten the spindle.
  4. Use a 15 mm wrench to tighten the spindle.
    Pedals on the bike with a wrench
    NOTE: To ensure accurate power measurements, you must tighten the pedals onto the crank arms to the recommended torque of 35 N-m (26 lbf-ft.).
  5. Repeat the previous steps to install the left pedal.
    NOTE: The left pedal spindle has a left-handed (reverse) thread.
  6. Move your bike chain to the largest chain ring and the smallest cassette gear.
  7. Rotate the crank arm to check for clearance.
    NOTICE
    You must make sure there is at least a 2 mm clearance between the pedal spindle and any part of the bike, such as the chain, groupset or frame. If any part of the bike frame, chain, or groupset touches the spindle while you are riding, it may damage the electronics in the spindle, causing product malfunction.
    Detailed view of the chain clearance
  8. If necessary, add one washer (included) between the spindle and the crank arm on both sides of the bike, to increase clearance and ensure evenness between both pedals.
    WARNING
    Do not add more than one washer to each pedal. Adding more than one washer may cause excess strain on the pedal spindle and threads, potentially leading to a product failure, property damage, or serious personal injury.
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
