Adjusting the Release Tension
WARNING
If you set the release tension too high, it may be difficult to quickly disengage from the pedal, potentially leading to personal injury in a fall. If you set the release tension too low, you may unintentionally disengage from the pedal, potentially leading to serious personal injury in a crash. Before riding, place one foot on the ground and practice engaging and disengaging from the pedal several times.
NOTICE
Do not overtighten the release tension screws. Overtightening the release tension screws may cause product damage.
  • For the Rally™ RS or Rally RK pedal bodies, use a 3 mm hex key to adjust the release tension screw.
  • For the Rally XC pedal bodies, use a 3 mm hex key to adjust the release tension screw equally on both sides of the pedal.
You should set the same release tension on both pedals to make sure you can clip in and out comfortably from both sides.
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
