Setting Your Device Passcode
If you enter your passcode incorrectly three times, the golf handheld locks temporarily. After five incorrect attempts, the golf handheld locks until you reset your passcode in the Garmin Connect™ app. If you have not paired your golf handheld with your phone, the device deletes your data and resets to the factory default settings after five incorrect attempts.
You can set up a device passcode to prevent unauthorized users from using your device.
Select an option:
During the initial setup, select OK when prompted to create a passcode.
Select .
- Enter a four-digit passcode.
- Re-enter the passcode.
- Select Timeout.
- Select a length of time of inactivity before the device prompts you to enter the passcode.
The next time you turn on the golf handheld, you must enter the passcode before you can view any information.
Parent Topic: System Settings
