System Settings
Select to customize the system settings.
- Language
Sets the language displayed on the device.
- Units
Sets the units of measure used on the device (Changing the Units of Measure).
- Time
Adjusts the time settings (Time Settings).
- Passcode
Sets or changes a four-digit passcode to secure your personal information (Setting Your Device Passcode).
- USB Mode
Sets the device to use MTP (media transfer protocol) mode or Garmin® mode when connected to a computer.
- Solar Auto Wake
Displays a screen with solar charging statistics when the device is turned off and detects sunlight.
- Battery Percent
Displays the remaining battery life as a percentage.
- Satellites
Allows you to select the preferred source for GPS data (Satellite Settings).
- Reset
Allows you to reset user data and settings (Restoring All Default Settings).
