Turning On the Device Manually
Before you turn on the device using battery power, you should fully charge the battery.
NOTE: When the device is connected to an ignition-switched power outlet, it turns on automatically when you turn on the vehicle.
Select Power symbol .
The device turns on.
GUID-D9E2A866-74A8-4380-BE21-F1522E0149BC v1
September 2024
