Pairing Your Wireless Sensors
The first time you connect a wireless sensor to your watch using ANT‍+® or Bluetooth® technology, you must pair the watch and sensor. If the sensor has both ANT‍+ and Bluetooth technology, Garmin® recommends that you pair using ANT‍+ technology. After they are paired, the watch connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. Move at least 10 m (33 ft.) away from other wireless sensors.
  2. If you are pairing a heart rate monitor, put on the heart rate monitor.
    The heart rate monitor does not send or receive data until you put it on.
  3. Hold Top button.
  4. Select Settings > Accessories.
  5. Select Add New.
  6. Select a sensor type.
  7. Bring the watch within 3 m (10 ft.) of the sensor, and wait while the watch pairs with the sensor.
    After the watch connects to the sensor, an icon appears at the top of the screen.
GUID-C3D54BBE-3966-4DA1-B60C-AD69DA5CC163 v2
October 2025
