Wireless Sensors
Your watch can be paired and used with wireless sensors using ANT+® or Bluetooth® technology (). After the devices are paired, you can customize the optional data fields (Customizing the Data Screens). If your watch was packaged with a sensor, they are already paired.
For information about specific Garmin® sensor compatibility, purchasing, or to view the owner's manual, go to buy.garmin.com for that sensor.
Sensor Type |
Description |
eBike |
You can use your watch with your eBike and view bike data, such as battery and range information, during your rides. |
External Heart Rate |
You can use an external sensor, such as the HRM 200, HRM 600, HRM-Fit™, or HRM-Pro™ series heart rate monitor, to view heart rate data during your activities. |
Foot Pod |
You can use a foot pod to record pace and distance instead of using GPS when you are training indoors or when your GPS signal is weak. |
Headphones |
You can use Bluetooth headphones to listen to music loaded onto your watch (Connecting Bluetooth Headphones). |
Rangefinder |
You can use a compatible laser rangefinder to view your distance to the flag while golfing. |
Speed/Cadence |
You can attach speed or cadence sensors to your bike and view the data during your ride. If necessary, you can manually enter your wheel circumference (Wheel Size and Circumference). |
Tempe |
You can attach the tempe™ temperature sensor to a secure strap or loop where it is exposed to ambient air, so it provides a consistent source of accurate temperature data. |
