Connecting the Wiring Harness to Power
WARNING
When connecting the power cable, do not remove the in-line fuse holder. To prevent the possibility of injury or product damage caused by fire or overheating, the appropriate fuse must be in place as indicated in the product specifications. Connecting the power cable without the appropriate fuse in place voids the product warranty.
  1. Route the wiring harness to the power source and to the device.
  2. Connect the red wire to the positive (+) battery terminal, and connect the black wire to the negative (-) battery terminal.
  3. If necessary, install the locking ring and O-ring on the end of the wiring harness.
  4. Insert the cable into the POWER connector on the back of the device, pushing firmly.
  5. Turn the locking ring clockwise to attach the cable to the device.
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
