Power/NMEA 0183 Cable
  • The wiring harness connects the device to power, NMEA® 0183 devices, and a lamp or a horn for visible or audible alerts.
  • If it is necessary to extend the power and ground wires, you must use a wire gauge appropriate for the length of the extension (Power Wire Extensions).
  • If it is necessary to extend the NMEA 0183 or alarm wires, you must use 22 AWG (.33 mm²) wire.
  • This cable provides one differential NMEA 0183 input and output port.
Cable with callouts
Item
Wire Color
Wire Function
Callout number 1
Red
Power
Callout number 2
Black
Ground (power and NMEA 0183)
Callout number 3
Blue
NMEA 0183 TxA (Out +)
Callout number 5
Gray
NMEA 0183 TxB (Out -)
Callout number 4
Brown
NMEA 0183 RxA (In +)
Callout number 6
Violet
NMEA 0183 RxB (In -)
Callout number 7
Orange
Accessory on
Callout number 8
Yellow
Alarm low
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
