Power Wire Extensions
If necessary, the power wires can be extended using the appropriate wire gauge for the length of the extension.
NOTE:
The power wires on this cable are red (+) and black (-). The other wires on this cable are used for other, optional connections and are not shown in this diagram.
Splice |
Fuse (8 A, 125 V fast-acting) The fuse should be installed as close to the battery as possible. When extending the power wires, remove the inline fuse and relocate it near the battery connection. |
20.3 cm (8 in.) |
Battery |
20.3 cm (8 in.) |
11 m (36 ft.) maximum extension |
Parent Topic: Connecting the Wiring Harness to Power
