Connecting the Fusion PartyBus Device to a Wireless Access Point
You can connect this device to a wireless access point on a router or compatible Fusion PartyBus™ device on the network. This device can connect using Wi‑Fi® Protected Setup (WPS), if it is supported by your access point (Connecting the Device to a Wireless Access Point Using Wi‑Fi Protected Setup). This device can connect using Apple® Accessory Configuration (WAC) using a supported Apple device (Connecting the Device to a Wireless Access Point Using Apple Wireless Accessory Configuration).
  1. Select Menu symbol > SETTINGS > NETWORK > WI-FI CLIENT > SSID.
    A list of wireless access points within range appears.
  2. Select the Fusion PartyBus wireless access point.
  3. If necessary, select PASSWORD, enter the password, and select Checkmark symbol.
  4. Select SAVE.
NOTE: After you connect the stereo to a wireless access point, you cannot use the wired network connection.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
