Connecting the Device to a Wireless Access Point Using Apple Wireless Accessory Configuration
If it is supported by Apple® device, you can connect this device using Wireless Accessory Configuration (WAC) instead of manually selecting the SSID and entering the password.
NOTE: You may need to see the owner's manual for your Apple device for information about using WAC.
  1. Select Menu symbol > SETTINGS > NETWORK > WI-FI CLIENT > WAC.
  2. Use your compatible Apple device to complete the connection.
NOTE: When you connect the stereo to a wireless access point, you cannot use the wired network connection.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
