Network Settings
NOTE:
If a
Garmin® chartplotter is detected on the network, the stereo automatically switches to
GARMIN MARINE NETWORK mode, and all other network settings are disabled.
TIP:
You can select the network status icon from any screen to open the network configuration menu.
Select .
- WI-FI OFF
Turns off all Wi‑Fi® wireless functions.
- WI-FI CLIENT
Configures the stereo as the wireless client, allowing it to wirelessly connect to other devices.
- WI-FI ACCESS POINT
Configures the stereo as the wireless access point (Setting the Fusion PartyBus Device as a Wireless Access Point).
- ADVANCED
Allows you to set the advanced wireless and wired settings, such as DHCP and SSID (Advanced Network Configuration).
- RESET
Resets all network settings for this stereo to the factory default values.
- Connecting the Fusion PartyBus Device to a Wireless Access Point
- Setting the Fusion PartyBus Device as a Wireless Access Point
- Advanced Network Configuration
- Resetting Network Settings
Parent Topic: General Settings
