Playing Golf
Before you play golf, you should charge the watch (Charging the Watch).
  1. From the watch face, press Upper-right button.
  2. Select Activities > Outdoor > Golf.
    The device locates satellites, calculates your location, and selects a course if there is only one course nearby.
  3. If the course list appears, select a course from the list.
  4. If necessary, set your driver distance.
  5. Select Check mark to keep score.
  6. Select a tee box.
    The hole information screen appears.
    Screenshot of the golf hole view with callouts
    1
    Current hole number.
    2
    Par for the hole.
    3
    Map of the hole.
    Colored dots indicate layup distances to the pin in meters or yards. Red is 100, white is 150, blue is 200, and yellow is 250.
    4
    Driver distance from the tee box.
    5
    Distances to the front, middle, and back of the green.
    NOTE: Because pin locations change, the watch calculates the distance to the front, middle, and back of the green, but not the actual pin location.
  7. Select an option:
    • Tap the front, middle, or back distances to the green to view the PlaysLike distance ( PlaysLike Distance Icons).
    • Press Middle-left button or Lower-left button to view additional data, including your handicap rating and the PlaysLike factors.
    • Tap the map to view more detail or measure distance with touch targeting (Measuring Distance with Touch Targeting).
    • Tap the map and press Middle-left button or Lower-left button to view the location and distance to a layup or to the front and back of a hazard.
    • Press Upper-right button to open the golf menu (Golf Menu).
When you move to the next hole, the watch automatically transitions to display the new hole information.
September 2026
