Golf Menu
During a round, you can press Upper-right button to access additional features in the golf menu.
View Map
Opens the map when the watch is in Big Numbers mode.
View Green
Sets the pin location to get a more precise distance measurement (Moving the Flag).
Virtual Caddie
Requests a club recommendation from the virtual caddie (Virtual Caddie).
Change Hole
Manually changes the hole.
Change Green
Changes the green when more than one green is available for a hole.
Scorecard
Opens the scorecard for the round (Keeping Score).
PinPointer
The PinPointer feature is a compass that points to the pin location when you are unable to see the green. This feature can help you line up a shot even if you are in the woods or in a deep sand trap.
NOTE: Do not use the PinPointer feature while in a golf cart. Interference from the golf cart can affect the accuracy of the compass.
Wind
Opens a pointer that shows the wind direction and speed relative to the pin (Viewing the Wind Speed and Direction).
Round Info
Shows the recorded time, distance, and steps traveled. This automatically starts and stops when you start or end a round.
Measure Shot
Shows the distance of your previous shot recorded with the Garmin AutoShot™ feature (Viewing Measured Shots). You can also manually record a shot (Manually Measuring a Shot).
Club Stats
Shows your statistics with each golf club, such as distance and accuracy information. Appears when you pair compatible Approach® club tracking sensors or enable the Club Prompt setting.
Custom Targets
Saves a location, such as an object or obstacle, for the current hole (Saving Custom Targets).
Add Back Nine
Adds the back nine holes when playing on a nine-hole course, allowing you to play a full round.
Sunrise & Sunset
Shows the sunrise, sunset, and twilight times for the current day.
Settings
Customizes the golf activity settings (Golf Settings).
End Round
Ends the current round.
September 2026
