Viewing Measured Shots
Your device features automatic shot detection and recording. Each time you take a shot along the fairway, the device records your shot distance so you can view it later.
TIP: Automatic shot detection works best when you wear the device on your leading wrist and make good contact with the ball. Putts are not detected.
  1. While playing golf, press Upper-right button.
  2. Select Measure Shot.
    Your last shot distance appears.
    NOTE: The distance automatically resets when you hit the ball again, putt on the green, or move to the next hole.
  3. Press Upper-right button and select Previous Shots to view all recorded shot distances.
    NOTE: The distance from the most recent shot also displays at the top of the hole information screen.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
