Measuring Distance with Touch Targeting
While playing a game, you can use touch targeting to measure the distance to any point on the map.
  1. While playing golf, tap the map.
  2. Tap or drag your finger to position the target circle Target.
    You can view the distance from your current position to the target circle, and from the target circle to the pin location.
  3. If necessary, use the slider on the right side of the screen to zoom in or out.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
