Activity Settings
These settings allow you to customize each preloaded activity based on your needs. For example, you can customize data screens and enable alerts and training features. Not all settings are available for all activity types. Some activity types have separate settings lists (Golf Settings).
From the watch face, press , select Activities, select an activity, press
, and select the activity settings.
- 3D Distance
Calculates your distance traveled using your elevation change as well as your horizontal movement over ground.
- 3D Speed
Calculates your speed using your elevation change as well as your horizontal movement over ground.
- Accent Color
Sets the accent color for the activity icon.
- Add Activity
Adds an activity type to a multisport activity.
- Alerts
Sets the training or navigation alerts for the activity (Activity Alerts).
- Audio Output
Enables connected audio devices for voice alerts (Playing Voice Alerts During an Activity).
- Auto Climb
Detects elevation changes using the built-in altimeter and automatically displays relevant climb data (Enabling Auto Climb).
- Auto Lap
Sets the options for the Auto Lap® feature to automatically mark laps. The By Distance option marks laps at a specific distance. The By Position option marks laps at a location where you previously pressed
. The Auto Select option triggers lap alerts on mile or kilometer course points when running a course with timing gates, such as some certified marathons, or at the distance set in the Auto Distance setting. When you complete a lap, a customizable lap alert message appears. This feature is helpful for comparing your performance over different parts of an activity.
TIP: You can create your own course with timing gates by turning on Auto Lap by Timing Gates when you create a course on the Garmin Connect™ app (Creating a Course on Garmin Connect ). - Auto Pause
Sets the options for the Auto Pause® feature to stop recording data when you stop moving or when you drop below a specified speed. This feature is helpful if your activity includes stop lights or other places where you must stop.
- Auto Rest
Automatically creates a rest interval when you stop moving during a pool swim activity (Swim Auto Rest and Manual Rest). Sets the options for automatically starting and stopping the rest timer for the ultra run activity (Ultra Run Auto Rest Settings).
- Auto Run
Automatically detects ski or water sport runs using the built-in accelerometer (Viewing Your Ski Runs, Viewing Your Water Sport Runs).
- Auto Scroll
Automatically scrolls through all of the activity data screens while the activity timer is running.
- Auto Set
Automatically starts and stops exercise sets during a strength training activity.
- Auto Sport Change
Automatically detects a transition to the next sport in a multisport activity, such as a triathlon.
- Auto Start
Automatically starts a motocross or BMX activity when you start moving.
- Broadcast Heart Rate
Automatically broadcasts heart rate data from your watch to paired devices when you start the activity (Broadcasting Heart Rate Data).
- Broadcast to GameOn
Automatically broadcasts biometrics data to the Garmin GameOn™ app when you start a gaming activity (Using the Garmin GameOn App).
- ClimbPro
Displays ascent information for upcoming and current climbs while navigating a course (Using ClimbPro).
- Countdown Start
Enables a countdown timer before the activity timer starts.
- Data Screens
Customizes data screens and adds new data screens for the activity (Customizing the Data Screens).
- Edit Weight
Prompts you to add the weight used for an exercise set during a strength training or cardio activity.
- Ending Alerts
Sets an alert for two or five minutes before the end of your meditation activity.
- Gear Selection
After you complete an activity, prompts you to select the gear or equipment you used during the activity. You can add and delete gear in your Garmin Connect account (Garmin Connect).
- Grading System
Sets the grading system for rating the route difficulty for a rock climbing activity.
- Jump Mode
Sets the jump rope activity target to a set time, number of reps, or open ended.
- Lane Number
Sets your lane number for track running.
- Laps
Configures the settings for the Auto Lap, Lap Key, and Lap Alert options.
- Lap Alert
Sets the data fields to show for laps.
- Lap Key
Enables the
button for recording a lap or rest during an activity. You can also define the default behavior for the
button for some activity types, such as multisport.
- Lock Device
Locks the touchscreen and buttons during a multisport activity to prevent inadvertent button presses and touchscreen swipes.
- Map Settings
Sets the display preferences for the map data screen for the activity (Map Settings).
- Map Layers
Sets the map data to show on the map (Showing and Hiding Map Data).
- Metronome
Plays tones or vibrates at a steady rhythm to help you improve your performance by training at a faster, slower, or more consistent cadence. You can set the beats per minute (bpm) of the cadence you want to maintain, beat frequency, and sound settings.
- Mode Tracking
Sets the ascent and descent tracking mode to automatic or manual for backcountry skiing and snowboarding.
- Obstacle Tracking
Saves obstacle locations from your first loop of the course. On repeat loops of the course, the watch uses the saved locations to switch between obstacle and running intervals (Recording an Obstacle Racing Activity).
- Pack Weight
Sets the weight of the pack you are carrying.
- Performance Condition
Enables the performance condition feature during an activity (Performance Condition).
- Pool Size
Sets the pool length for pool swimming.
- Power Averaging
Controls whether the watch includes zero values for bike power data that occur when you are not pedaling.
- Power Mode
Sets the default power mode and low battery power mode for the activity (Customizing the Power Mode for an Activity).
- Power Save Timeout
Sets the timeout limit for the watch to stay in activity mode while waiting for you to start the activity, for example, when you are waiting for a race to start. The Normal option sets the watch to enter low-power watch mode after 5 minutes of inactivity. The Extended option sets the watch to enter low-power watch mode after 25 minutes of inactivity. The extended mode can result in shorter battery life between charges.
- Record After Sunset
Sets the watch to record track points after sunset during an expedition.
- Record Temperature
Records the ambient temperature around the watch or from a paired temperature sensor.
- Record VO2 Max.
Records a VO2 max. estimate for trail run and ultra run activities.
- Recording Interval
Sets the frequency for recording track points during an expedition. By default, GPS track points are recorded once an hour, and they are not recorded after sunset. Recording track points less frequently maximizes battery life.
- Rename
Sets the activity name.
- Rep Counting
Records rep counts during a workout. The Workouts Only option records rep counts during guided workouts only.
- Repeat
Records repeats for multisport activities. For example, you can use this option for activities that include multiple transitions, such as a swimrun.
- Restore Defaults
Resets the activity settings.
- Route Stats
Records route statistics for indoor climbing activities.
- Routing
Sets the preferences for calculating routes for the activity (Routing Settings).
- Running Power
Records running power data and customizes the settings (Running Power Settings).
- Runs
Configures the settings for the Auto Run, Lap Key, and Lap Alert options.
- Satellites
Sets the GNSS satellite system to use for the activity (Satellite Settings).
- Segment Alerts
Notifies you about approaching saved segments (Segments).
- Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Evaluating an Activity).
- SpeedPro
Records advanced speed metrics for windsurf activity runs.
- Stroke Detection
Automatically detects your stroke type for pool swimming.
- Swim Wrist
Sets the wrist you wear the watch on for swimming activities.
- Touch
Enables the touchscreen during an activity or only for the map screen.
- Touch Lock
Enables swiping down from the top of the screen to unlock the touchscreen.
- Track Detection
Automatically detects if you are on a track for running.
- Transitions
Enables transitions for multisport activities.
- Units
Sets the units of measure for the activity.
- Vibration Alerts
Notifies you to inhale or exhale during a breathwork activity.
- Workout Videos
Plays instructive workout animations for a strength, cardio, yoga, or Pilates activity. Animations are available for pre-installed workouts and workouts downloaded from your Garmin Connect account.
- Customizing the Power Mode for an Activity
- Activity Alerts
- Playing Voice Alerts During an Activity
- Routing Settings
- Using ClimbPro
- Enabling Auto Climb
- Satellite Settings
- Segments
