Customizing the Power Mode for an Activity
You can customize the enabled features and estimated battery life for an activity. The watch displays the estimated hours of battery life available for each power mode.
  1. From the watch face, press Upper-right button.
  2. Select Activities, and select an activity.
  3. Press Lower-left button.
  4. Select the activity settings.
  5. Select Power Mode.
  6. Select an option:
    • To change the default power mode for the activity, select Default Mode, and select an option.
    • To change when the low battery alert appears for the activity, select Low Battery Alert.
    • To change when the power mode automatically changes when the battery is low, select Auto Enable Time.
    • To automatically change the power mode when the low battery alert appears, select Auto Enable Mode.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v10
November 2026
