Running Dynamics
Running dynamics is real-time feedback about your running form. Your fēnix® watch has an accelerometer to calculate five running form metrics. To view all of the running form metrics, you must pair your fēnix watch with the HRM 600, HRM-Fit™, HRM-Pro™ series accessory, or other running dynamics accessory that measures torso movement. For more information, go to garmin.com/performance-data/running.
Metric |
Sensor Type |
Description |
Cadence |
Watch or compatible accessory |
Cadence is the number of steps per minute. It displays the total steps (right and left combined). |
Stride length |
Stride length is the length of your stride from one footfall to the next. It is measured in meters. |
Vertical oscillation |
Vertical oscillation is your bounce while running. It displays the vertical motion of your torso, measured in centimeters. |
Vertical ratio |
Vertical ratio is the ratio of vertical oscillation to stride length. It displays a percentage. A lower number typically indicates better running form. |
Ground contact time |
Ground contact time is the amount of time in each step that you spend on the ground while running. It is measured in milliseconds.
NOTE:
Ground contact metrics are not available while walking.
Ground contact time balance |
Compatible accessory only |
Ground contact time balance displays the left/right balance of your ground contact time while running. It displays a percentage. For example, 53.2 with an arrow pointing left or right. |
Step speed loss |
HRM 600 only |
Step speed loss is how much you slow down when your foot hits the ground while running. It is measured in centimeters per second. A lower number is typically better, as it indicates you have to do less propulsive work to speed back up.
NOTE:
Step speed loss metrics are not available while walking.
Step speed loss percentage |
HRM 600 only |
Step speed loss percent is how much you slow down when your foot hits the ground as a percentage of your running speed. This accounts for step speed loss typically increasing with faster running speed. |
Tips for Missing Running Dynamics Data
This topic provides tips for using a compatible running dynamics accessory. If the accessory is not connected to your watch, the watch automatically switches to wrist-based running dynamics.
Running Power
Garmin® running power is calculated using measured running dynamics information, user mass, environmental data, and other sensor data. The power measurement estimates the amount of power a runner applies to the road surface, and it is displayed in watts. Using running power as a gauge of effort may suit some runners better than using either pace or heart rate. Running power can be more responsive than heart rate for indicating the level of effort, and it can account for the uphills, downhills, and wind, which a pace measurement does not do. For more information, go to garmin.com/performance-data/running.
Running power can be measured using a compatible running dynamics accessory or the watch sensors. You can customize the running power data fields to view your power output and make adjustments to your training (Data Fields). You can set up power alerts to be notified when you reach a specified power zone (Activity Alerts).
Running power zones use default values based on gender, weight, and average ability, and may not match your personal abilities. You can manually adjust your zones on the watch or using your Garmin Connect™ account (Setting Your Power Zones).
Running Power Settings
From the watch face, press , select Activities, select a running activity, scroll down, select
the activity settings, and select Running Power.
- Status
Enables or disables recording Garmin running power data. You can use this setting if you prefer to use third-party running power data.
- Source
Allows you to select which device to use to record running power data. The Smart Mode option automatically detects and uses the running dynamics accessory, when available. The watch uses wrist-based running power data when an accessory is not connected.
- Account for Wind
Enables or disables using wind data when calculating your running power. Wind data is a combination of the speed, heading, and barometer data from your watch and the available wind data from your phone.
