Installing the Transducer on the Perspective Mode Mount
You can use the perspective mode mount to install the transducer in the perspective or side shaft configuration.
Labels identifying the parts bags required for this procedure:
Remove the perspective mode
bracket from parts bag
Remove the adapter disc from
parts bag
, which is located within parts bag
Remove the back half of the
mounting bracket and four screws from parts bag
NOTE: For a shaft diameter greater than 42 mm (1.65 in.), use the four screws from parts baginstead.
Remove the knob from parts bag
If the trolling motor shaft is
equal to or less than 25 mm (1 in.) in diameter, remove the rubber liner from
parts bag
- Identify the arrow on the front half of the mounting bracket to ensure you install the bracket in the correct orientation when you secure it to the trolling motor.
If you are installing the
transducer on a shaft equal to or less than 25 mm (1 in.) in diameter, wrap the
rubber liner
around the shaft at the location where you plan to install the bracket.
NOTE: The rubber liner is recommended for any shafts smaller than 38 mm (1.5 in.). The perspective mount does not support shafts smaller than 31 mm (1.25 in.). -
Orient the mounting bracket
on the shaft
so the arrows on the inside of the front half of the bracket point upward.
The bracket should be aligned so the notch in the bracket lines up with the groove in the trolling motor shaft.
Insert the screws into the back of
the mounting bracket , and secure them to the front bracket using the 5 mm hex wrench
in parts bag
Transition the trolling motor
from the deployed to the stowed position and back again to test the location of
the mounting bracket and make any adjustments as needed.
NOTICE
If you are mounting onto a Force® or Force Pro trolling motor, you must install the perspective mount in the proper location so that the transducer aligns with the latch gap. Failure to do so can result in damage to your transducer or trolling motor.
- Remove the adhesive liner from the back of the adapter disc .
- Attach the adapter disc to the end of the mount arm by aligning the 3 pegs on the adapter disc with the holes in the bracket .
Place the transducer against the adapter
disc, and attach it using the knob .
NOTE: You can secure the transducer to the extension arm using the included low-profile hardware instead of the knobs if you do not plan to switch transducer modes frequently during use (Installing the Transducer Using Low Profile Mounting Hardware).
Secure the transducer cable to
the shaft or other secure location.
NOTICE
You must route the cable so it does not come in contact with the propeller when the trolling motor is operating.
You should not route the cable close to electrical wires or other sources of electrical interference.
You must route the cable so it is not pinched when the trolling motor is deployed or stowed.
Failure to adhere to these guidelines can result in property damage or damage to your device.
NOTE: Leave a small amount of slack in the transducer cable before securing it so you can rotate the transducer between viewing modes as needed.NOTE: If necessary, you can connect an optional extension cable, available at buy.garmin.com or from your Garmin® dealer. - Position the transducer at your preferred angle (Viewing Modes).
