Viewing Modes
Using the perspective mode mount, you can change the orientation angle of the transducer between three sonar views.
When installing the transducer using the recommended adjustment knobs, no tools are necessary to change the orientation between these fields of view. You must loosen the knobs to change the orientation of the arm and transducer, and tighten them to set the orientation.
You can verify the sonar view using the notches on the perspective mount bracket and the transducer.
NOTE: The notches are labeled on the transducer hardware and bracket, so you can use these tables and diagrams to match the notches and understand the positioning of the transducer and perspective view bracket when changing between sonar views.
NOTE: The transducer is labeled with markings to configure the sonar view for both the port and starboard side, so you can choose the configuration based on your installation arrangement.
Viewing mode positions with callouts
Glyph Disc Marking Meaning
A
F|D
Starboard side forward or downward view
B
P
Perspective view
C
F|D
Port side forward or downward view
1
D
Port side downward view
2
F
Port side forward view
3
P
Perspective view
4
F
Starboard side forward view
5
D
Starboard side downward view
1: Viewing Mode Examples on the Port Side
Viewing mode positions from port with callouts
1
Perspective view (notches B and 3)
2
Forward view (notches C and 2)
3
Downward view (notches C and 1)
2: Viewing Mode Examples on the Starboard Side
Viewing mode positions from starboard with callouts
1
2
Forward view (notches A and 4)
3
Downward view (notches A and 5)
You should align the marks on the transducer and bracket to verify the appropriate orientation before tightening the knob.
GUID-9C83E43A-D15D-4D48-9AF6-AF0CBFA49D98 v4
October 2026
