Power Connection
When connecting the stereo to power, you must connect the yellow, red, and black wires to the power source. The yellow and red wires have different functions, and the method you use to connect them to power depends on how you plan to use the stereo on your vessel.
NOTICE
When you are not using the vessel for an extended period of time, you should remove power to the stereo to avoid draining the battery.
Yellow wire
  • This wire provides power to the stereo.
  • This wire must be connected through an appropriately-rated circuit breaker or inline fuse (Important Power Connection Information for New Installations)
  • This wire provides power to the stereo at all times, and it will drain the battery even when the stereo is not in use. You should install a manual switch on this wire if a circuit breaker is not available on the vessel, or if you cannot toggle the breaker to remove power to the stereo when storing the vessel.
  • When extending this wire, the required wire gauge depends on the length of the extension and the connected power source (Power Cable Gauge Guide)
Red wire
  • This wire can be connected to the same power source as the yellow wire through the ignition or through a manual switch. This enables you to turn the stereo on and off automatically when you turn the vessel on and off, or when you activate the switch.
  • Using this wire to turn the stereo on and off behaves in the same way as using the power button on the stereo to turn it on and off. It is not necessary to connect this wire through the ignition or manual switch if you plan to toggle the power using the power button on the stereo or using a connected chartplotter or remote control, and can instead be tied together with the yellow wire. This wire must be connected to turn the stereo on.
  • When you turn off the stereo using this switch or the power button, it enters a standby mode that allows the stereo to start up again faster than if you switch the power off using the yellow wire. When it is in standby mode, the stereo uses up to 350 mA, and you must turn off power to the stereo on the yellow wire through the circuit breaker or manual switch when you are not using the vessel to avoid draining the battery.
  • WARNING
    You must connect this wire to power through a 1 A fuse (not included), whether or not you connect it to the ignition or manual switch. Connecting this wire to power without a fuse could result in a short on the wire, which may lead to over heating and a possible fire.
  • If it is necessary to extend this wire, use 22 AWG (0.33 mm2) wire.
Black wire
  • This is the ground wire, and you must connect it to the negative terminal of the power source or to a common ground.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
