Connecting to Power Without Using an Ignition Switch
This method of connection is used most often on larger vessels and on vessels with multiple networked stereos and other marine devices. For these installations, a faster startup time is typically less critical, and it is more effective to use the breaker or a dedicated switch on the electrical panel to turn off the stereo and ensure that no unexpected power drain occurs.
NOTICE
When you are not using the vessel, you should remove power to the stereo using the circuit breaker or manual switch to avoid draining the battery.
  1. Consult this diagram to plan the wire connections.
    Wiring diagram with callouts
    Item
    Description
    Notes
    1
    Yellow wire
    You should connect this wire to the red wire before you connect both wires to the manual switch or circuit breaker.
    2
    Red wire
    You should connect this wire to the yellow wire so that it does not act as a physical standby switch.
    3
    1 A fuse (not included)
    You must install this fuse on the red wire before you connect the red wire to the yellow wire.
    4
    Manual switch (optional)
    This switch is needed only if a circuit breaker is not available or if you require a more-convenient method of cutting power to the stereo.
    5
    Black wire
    Ground (-)
    You must connect this wire to the same ground as the power source, or to a common ground.
    6
    Appropriately-rated inline fuse or circuit breaker (Important Power Connection Information for New Installations)
    An appropriately-rated fuse or circuit breaker is required and must be rated for the current requirements of the stereo installation and the power cable used. The fuse or circuit breaker must be located at the battery end of the supply cable.
    7
    Appropriately-rated circuit breaker for a power-distribution cable (Important Power Connection Information for New Installations)
    If the stereo is connected to a power-distribution cable or bus that also supplies other equipment, this should include a fuse or circuit breaker rated for the power-distribution cable used. This fuse or circuit breaker must be located within 150 mm (6 in.) of the battery.
  2. Route all wires to the stereo wiring harness, the circuit breaker or switch, and the power source as necessary.
    Do not connect the wiring harness to the stereo until after you have made all of the bare wire connections.
  3. Install all of the necessary fuses on the red and yellow wires.
  4. Connect the wiring harness to the stereo.
When the circuit breaker or manual switch on the combined yellow and red wires is closed, the stereo is always on. You can use the power button on the stereo or a connected chartplotter or remote control to place the stereo in a low-power standby mode if needed.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
