Setting the Fusion PartyBus Device as the DHCP Server
If you connected more than two network devices together using a network switch or wireless access point but you did not install a router, you should configure only one Fusion PartyBus™ stereo to be a DHCP server.
NOTICE
Having more than one DHCP server on the network causes instability and poor performance for all devices on the network.
NOTE: If you have set up this stereo as a WI-FI ACCESS POINT, it is configured as a DHCP server by default, and no further settings changes are needed (Setting the Fusion PartyBus Device as a Wireless Access Point).
  1. If the device is connected to the network using an Ethernet cable, select Menu > SETTINGS > NETWORK > WI-FI OFF.
  2. If the device is connected to the network using an Ethernet cable, select STATIC IP > SAVE.
  3. Select ADVANCED > DHCP SERVER > DHCP ENABLED > SAVE.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
