Setting the Fusion PartyBus Device as a Wireless Access Point
Before you can connect additional Fusion PartyBus™ devices or smartphones to a Fusion PartyBus device wirelessly, you must configure one device as a wireless access point. This is not necessary if you installed a wireless router or other wireless access point on the network.
NOTICE
You should not configure this device as a wireless access point if you have a router installed on the network. Doing so may introduce DHCP conflicts and result in poor network performance.
For more detailed configuration instructions, see the owner's manual.
  1. Select Menu > SETTINGS > NETWORK > WI-FI ACCESS POINT.
  2. Select USE DEFAULTS and wait for the device to save the network settings.
    NOTE: After the default settings are saved, you can scroll down to the bottom of the NETWORK menu to view the default SSID assigned to the access point.
  3. Select Menu > SETTINGS > NETWORK > ADVANCED > WI-FI AP SETTINGS > PASSWORDand enter a password for the wireless access point.
NOTE: When you configure the stereo as a wireless access point, you can also use the wired network connection without changing any additional settings. The wired and wireless networks are bridged.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
