Changing the Heading Hold Behavior
By default, the Heading Hold feature is set to Go To mode, which may adjust your heading to compensate for drift and keep your boat moving in the same direction. If preferred, you can configure the Heading Hold feature to use Vessel Align mode, which ignores drift and simply keeps the bow of your boat pointing in the same direction.
  1. On the remote control, select Menu icon > Settings > Trolling Motor > Heading Hold.
  2. Select Vessel Align.
You can select Go To to revert back to the default Heading Hold behavior.
GUID-91136105-7EB2-442E-8C25-7B4CF00FC466 v3
July 2026
