Mounting Considerations
You can mount the device using one of three methods.
Bail mount
You can mount the device using the bail mount, which allows you to tilt the device.
Swivel mount
You can mount the device using the swivel base and bail mount, which allows you to swivel and tilt the device.
Flush mount
You can mount the device in the dashboard, which provides a more integrated installation.
Before permanently installing any part of your device, you should plan the installation by determining the location of the various components.
  • The mounting location must provide a clear view of the screen and access to the keys on the device.
  • The mounting location must be sturdy enough to support the device and the mount.
  • The cables must be long enough to connect the components to each other and to power.
  • To avoid interference with a magnetic compass, do not install the device closer to a compass than the compass-safe distance value listed in the product specifications (Specifications).
GUID-8FDBCF2B-E4C1-48B8-BFBC-D3C00EC9A832 v4
December 2025
