Fixed-Bail Mounting the Device
NOTICE
If you are mounting the bracket on fiberglass with screws, it is recommended to use a countersink bit to drill a clearance counterbore through only the top gel-coat layer. This will help to avoid cracking in the gel-coat layer when the screws are tightened.
  1. Select the mounting hardware appropriate for the bail-mount bracket 1 and your mounting surface.
    Fixed bail mount with callouts
  2. Using the bail-mount bracket as a template, mark the pilot holes through the screw holes.
  3. Using a drill bit appropriate for the mounting hardware, drill the four pilot holes.
  4. Using the selected mounting hardware 2, secure the bail-mount bracket to the mounting surface.
  5. Loosely install the bail-mount knobs 3.
  6. Place the device 4 in the bail-mount bracket.
  7. Tighten the bail-mount knobs.
GUID-8FDBCF2B-E4C1-48B8-BFBC-D3C00EC9A832 v4
December 2025
