Flush Mounting the Device
Be careful when cutting the hole to flush mount the device. There is only a small amount of clearance between the case and the mounting holes, and cutting the hole too large could compromise the stability of the device after it is mounted.
Using a metal pry tool such as a screwdriver can damage the trim caps and the device. Use a plastic pry tool when possible.
You can mount the device in your dashboard using the flush-mount template and appropriate hardware.
Parent Topic: Mounting Considerations
