Removing the Coil Cable from the Shaft Cap
Before you can remove the coil cable from the shaft cap, you must disconnect the cables in the shaft cap (Disconnecting the Cables in the Shaft Cap).
TIP:
Count and record the number of coils in the coil cable before removing it to simplify reinstallation.
Parent Topic: Disassembly Procedures
