Starting the Countdown Timer
- Hold the touchscreen to view the menu.
Select
- Set the minutes.
- Tap the center of the touchscreen to select the minutes and move to the next screen.
- Set the seconds.
Tap the center of the touchscreen to select the seconds and move to the next screen.
A screen appears showing the countdown time.
If necessary, select
to edit the time.
- Double-tap the touchscreen to start the timer.
- If necessary, double-tap the touchscreen to pause and resume the timer.
- Double-tap the touchscreen to stop the timer.
to reset the timer.
Parent Topic: Clocks
